engine ID question ?
I am setting the cam timing on a 77` 2.7 motor and need to know which spec is correct for that engine. The manual lists engines as 901/03 , 901/05 , 901/07 and so on. Which is the correct engine ID# for a 77` 2.7 ?
Thanks |
Oh yea, if you are using new chains should you lean more in one direction (more advanced) for correct cam timing considering chain stretch on initial break in ?
Type # for '77 ROW 2.7L is 911/81.
For 911S USA 50 state is 911/85. For 911S Japan is 911/94. All share the same valve timing as 911/42, the 1975 2.7L 911S CIS engine: In opens 6 ATDC In closes 50 ABDC Ex opens 24 BBDC Ex closes 2 BTDC (all information taken from B.A. bible #2, pages 109 and 110). |
thanks
| All times are GMT -8. The time now is 11:21 PM. |
