I use the manual lockout for the track; works perfectly. When driving around town, which isn't often for me, you have to be pretty clumsy to nick reverse even without the lockout.
jhtaylor santa barbara 74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's. 73 Targa (gone but not forgotten) |
86FlatSix
Any of you guys experience 1st gear popping out? Is it just me getting used to the new shifter or something is wrong with my tranny? I noticed I get a 30% chance of 1st gear popping out from a stop. Either I don't put 1st properly or I need to adjust again. I just drove it around for an hour on stop and go and fwy traffic and enjoyed it. Except for those awkward moments when you were about to go after the green and the gear pops out and you are left there by the pack for a few seconds. lol
74 BMW 2002 (rust rocket) 86 911 Coupe (weekend warrior) 09 997.2 C2 (semi-daily) |
JQ, it sounds like an adjustment problem. Loosen your coupler clamp slightly, and pull your shift lever back just a little while holding the coupler fixed. That should allow you to push the coupler further into first.
Just an idea that worked for me. Good luck, Dave
Dave McKenzie 1984 Carrera 3.2 1984 928S Automatic 2001 996TT |
Reiver
I put the Rennshift in my '83 euro today.
I had replaced all bushings and coupler bushings prior and was running a seine system. The seine system was a great improvement over stock and made the 3-4 plane very evident so you'd have to be ham fisted to select the wrong gear....it works. I simply wanted a better looking unit specifically made to improve the poor gear selection Porsche designed (one side spring loaded?). The Rennshift is a quality upgrade and an easy install altho the short shift takes a bit of getting use to after rowing gears. The only adjustment change I made was a 1/32 to 1/16th in. moving the coupler aft so even depth occurred in gears fore/aft....I had no adjustment to make clockwise or counter. I think many miss the importance of the depth issue and minute changes reap great benefit. I use the manual lockout and it worked perfectly with no adjustment to anything. I think if you have major adjustment to your coupler counter or clockwise you were already way out of adjustment because of some slop in your prior system. It is more direct and snicky that the stock + seine and the shorter throws are nice too. It is also a very functional beauty type of item. I believe it also very fairly priced. Happy camper.
De Oppresso Liber Strength and Honor 5th Legion |
I bought the Rennshift last year and finally got around to putting it in last weekend, finishing up today. Overall, I give the product a thumbs up. However, I've had the same problems with the reverse pawl as many others.
There was one slight issue with the pawl that I definitely had to correct. It was contacting the upper ring which holds down the centering springs such that it would get locked forward after the lever was put into 5th, and then click back. I took the ring off and there were clear rub marks where the pawl was hitting the aluminum. I filed the aluminum down a little bit and that solved the problem. I've also adjusted everything as well as I can get it and the pawl seems like it could be a bit smoother. I'm a bit tempted to file the tip of the pawl down just slightly but I'm going to drive it a bit and maybe try one more adjustment after that.
1986 911 Carrera Coupe 2016 VW Golf R 2008 Toyota Highlander (boring, reliable, quiet, wife likes it) |
Another Rennshifter question. The 'throw' into 2nd and 4th on my setup is noticeably shorter than it is into 1st and 3rd. Can I change this by moving the lever forward or backward a tad after loosening the coupler?
I need to take another crack at adjusting mine after I drive it and I'll tell if you I see anything that could cause that.
Just installed the Rennshift in my 78SC - beautiful assembly and very easy install. I bought the package with the shift coupler and a new rod bushing. Everything feels tight and precise, vast improvement noticed on a brief shakedown drive. So far the initial adjustment seemed to do the trick, easy to find all gears and nothing popping out under acceleration.
Stupid question - what are the two extra cone screws for? The cone screw in the coupler looks to be the same size but why would I need two spares? Or did I completely overlook two other screws that could be replaced?
1978 911SC |
I do not remove the supplied standard screw that comes with the coupler, so that is your extra. The one you missed is the cone screw under the shifter holding the cup to the front of the shift rod. You remove this one to replace the shift rod bushing. |
1978 911SC |
83 SC
Installed my new Rennshifter in my 83sc over the weekend and love it. So much more refined than my stock unit and made my old 915 shift easier. Great upgrade. Tim
hi
it seems some are fitting the shifter totally over the carpet original fit for the shifter is under the carpet any reason ? appart of esthetic reasons ? thanks |
No. Do what you like.
Thread Tools | |
Rate This Thread | |
