"clunk" like a rattling metal trash cans?
Take a video clip of it and post it. |
Can you tell what area the clunk is from?
I agree with Draco, try to do a video or sound recording of the problem. |
Agreed that a recording makes sense, I'll see what I can do tonight. Describing a sound in text is always pretty worthless. :D
As for location, its pretty hard to pin point. I used my stethoscope on each of the intake runners and just got the sound of cold tappy valves, so it doesn't appear to be coming from one of the cylinders specifically. |
What would happen if you removed the Wong chip and put the original back in? Or are we past that point, due to the 4k mod?
If the DME was 2K with the 2K chip and it was Modified for the 4K chip you can't just put in the 2K chip. You need to undo the modification. Or better yet obtain a factory 4K chip if possible, if you have a SW 4K chip and a factory 4K chip you can swap them whenever you like.
This is exactly why when I convert DMEs to 8K 1989 chip specs with the 28pin chip I always deliver the DME with the factory 8K chip and then any other of my perf chips of choice. But I doubt the SW 4K chip is the source of the clunking issue. The SW chips are well done and are a good product. Not sure why you want to go back to a factory chip? Although I agree it's a very nice option to be able to go back to factory chip. |
To save the tabs on the case I don't crimp them back, I simply use a large tie wrap to hold the case in place. This way if you open the case again you just cut the tie-wrap. Or better yet get a long Velcro strap.
How old is your battery?
If it is running well enough to drive, you can bring it by this evening and we could all brainstorm on it. I have the Bentley and the Pelican Forum at hand.:)
Something similar happened with a friends car of a different brand.
He stalled it by slipping off the clutch by accident. Then, it wouldn't turn over after using the starter motor Eventually we push started it and it had an ungodly clatter. It turned out to be the clutch. Apparently when he stalled it he sheered the rivets that hold the clutch plates together. It was old and just suddenly failed when his foot slipped off the clutch and it violently engaged. No other damage, just a blown clutch pack. If that is the situation with yours it may be that at speed it sits properly but moved around without the centrifugal force from turning higher RPMs? |
Any updates? Do we need to get a group to come by and analyze the situation?
You can remove the ac belt and listen then fan belt and listen ( but for a a minute or two no longer ).
CCM, he will come around eventually :D " you can lead a horse..." |
| All times are GMT -8. The time now is 12:15 AM. |
