I have 3 leavers I just disconnected the fresh air box cable and made sure it is in the closed position taped it shut. the middle leaver is all the way to the left all doors on that are shut. My defrost lever was getting hung up on the wires that ran behind it on the driver side. I now have that all the way to the left. Soon as I get done work I will see what happens. If it's still cold I will move the wires and Move it all the way to the right. |
Wires.
Be very carefull with those wires as they are one of the primary reasons for for a harness fire. Also, "while your're in there" fuse your dash light(s) harness, and position those wires in a permanent location as they have a tendency to move around. Good luck, Gerry |
I found the heat god yayhttp://forums.pelicanparts.com/suppo...ys/men_ani.gif
My toes were nice and toasty on the way home tonight, I need to move those wires out of the way so the door opens for the defrost lever. I am still adding the rear blower motor and footwell blowers, I want to be a pizza. Just want to say thanks guy and other post on pelican. Oh one more how do you adjust the cable for the levers. SmileWavy |
| All times are GMT -8. The time now is 04:40 AM. |
