85 911 Questions
There is a tube on the right side that travels from the trunk to the passenger footwell blower area. It is about 1-1/4 in. in diameter. Both ends were originally covered with plastic/rubber caps. They disintegrated when I touched them. Does anyone know what this passage was for?
Also, has anyone reparied a rear bumper guard? I have a hole in one of mine, but I can't think of a way to properly repair it so it would look good. Any leads on where to find a good, used one? I have tried the obvious sites, but with no luck. I know our host and an aftermarket supplier have them, but $$$$$$$$$- OUCH! Thanks. From the passenger side footwell area. The footwell blower has been removed. ![]() From the trunk area. ![]() ![]()
Just wait for the bumper guards to pop up in the used parts section. Plenty of people remove them for weight savings(which you could also do).
1985 911 3.2 Carrera Coupe - Constant Project - 2550lbs 2005 E46 M3- Daily Beater - 3350lbs |
It looks like the hole is where the cardboard tube goes to supply air the AC vents on the sides. The little bitty vents that are almost useless near the door.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Just a heads up, if those yellow wires threaded through the small hole are distributing power I'd be concerned about a fire or a short.
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera |
pm me on the bumper. I may have one. Which side is it? I believe GH85Carrera is correct. I thought this is where the footwell blowers connected?
John- 78 Slick Top 930 "Illegitimi non carborundum" Last edited by sundevil64; 11-12-2014 at 12:38 PM.. |
pic
Here is a pic of the passenger side.
John- 78 Slick Top 930 "Illegitimi non carborundum" |
No, it's not where the footwell blowers connect. I removed those and those hoses/ducts are different. These small openings actually had caps on them. I will check to see if the side vents in the dash are connected. That also means there is a connection on the other side, the trunk side, that is open.
The yellow wires are speaker wires for an aftermarket stereo the PO had installed. They are going. Thanks to all. |
