1987 911 shifter bushings?
My shifter just got a " loose and metallic feel" with a metal to metal sound, got online to order a set of shifter bushings and found none for a 1987.
Any suggestions? Thanks, Jack Gresham 1987 911 non turbo. |
Jack,
I recently posted this thread on overhauling both the shifter shaft seal and the shift bushing. Shift Rod Bushing here in red, p/n L-424-224-03: Is probably what you are looking for. The April 2002 Excellence also has a good article on overhauling the shifter. Let me know if I can be of any help. Don
Don Plumley M235i memories: 87 911, 96 993, 13 Cayenne |
You might also want to replace the cup bushing:
As well. |
while you are at it , take the cross shafts apart
and polish and grease them. makes a big differance and make sure you get the rubber o-rings back in correctly. keith |
