mfi throttle bodies
hi. can someone please let me know what is the correct way to adjust both of my throttle body stops. im having trouble with my idle being too low on my 73e targa. im thinking theres butterflies aren't opened enough. thanks
First...loosen all connectors in the system near the throttle bodies...then adjust each throttle plate with its stop (use a Unisyn or similar)...then carefully tighten the linkages being very careful to not affect the individual throttle plates.
Once you have all the plates in sync...and moving together at the same rate...it will be easier to adjust the idle. I like to allow the plates to close gently on their respective stops so that when the throttle is closed it really is closed. Then the over-all idle is just one screw. Bob
Bob Hutson |
