muffler bolts
Removing my stock muffler required cutting two of the three bolts due to rust. The cat bracket was also rusted out. I found the cat bracket and new gasket at Pelican, but no muffler bolts/nuts. I am looking for recommendations/sources. 1985 911 Targa with 3.2. Thanks.
Can you go to local hardware store and use SS metric bolts with plenty of copper anti-seize? I think I have done this in the past with no real problem. The bolts are not chassis/structural.
Good luck, Dave
Dave McKenzie 1984 Carrera 3.2 1984 928S Automatic 2001 996TT |
^what he said
My hardware store was out of SS bolts in the size I needed so I just used some galvanized ones. I'll change them out to stainless with anti-sieze next time I have the muffler off, no big loss if they have to be cut.
1981 911SC restomod "Minerva" 2004 Boxster S 2021 Cayman GTS 4.0 manual "Olive" 2014 Cayenne GTS V8 (wife's lover) The slope is not slippery; in fact it is entirely frictionless. |
Thanks gents, that is what I will do.
Mike |
Steel including galvanized tends to rust. Stainless will gall. If it as me it would be stainless bolts with copper or bronze nuts and anti seize.
