Where does the ground strap attach to the alternator
I bought this 3.0 with the engine harness already removed and now I'm having trouble figuring out how to wire it back up. I think I have the brown, blue and red wire correct, but I have a braided line that connects on one end to the case. Where does the other end connect?
http://forums.pelicanparts.com/uploa...1416194672.jpg |
Braided ground cable connection.......
If my memory serves me right, I think it's connected to one of the studs holding the air diverter. The ones (studs) shown in the picture (alternator fan housing). Tony |
Tony is right. It will only reach the closest stud so there is no confusion.
Here is the only photo I have. The ground strap is currently disconnected in this photo but it was bolted onto the lower stud that the fan diverter was connected to.
http://forums.pelicanparts.com/uploa...1416206295.jpg |
It is connected to the 6mm stud that is coming off the diode pack
It is a 10 gauge brown wire not a braided strap The braided strap was used on earlier engines |
Thanks, The connectors on the ends of the braided line would support the connection to the bolt on the case.
| All times are GMT -8. The time now is 08:38 PM. |
