Where does this hose go?
With the CV's rebuilt, I enjoyed some spirited driving yesterday. That was fun, but my engine surge under load problem has gotten much, much worse. I'm about 90% sure it is the air flow meter. (these problems come in threes, right? I'm rapidly losing my sense of humor.)
Anyway, as I was contemplating taking the AFM off again, I noticed a hose attached to nothing. I assume it is a vacuum hose of some sort. It is attached to a do-hickey (technical term, sorry) mounted above the oil filler. Here is a pic of the do-hickey: http://forums.pelicanparts.com/uploads/dohickey.jpg The hose ends up about in the middle of the engine by all the intake plumbing (it was along the firewall down low, I've pulled it up for clarity): http://forums.pelicanparts.com/uploads/hose.jpg I've looked all over using a mirror and flashlight and can't find where this hose goes. Any ideas? Thanks! Don |
I think it found it....
Still, anyone know what the do-hickey is called/does? |
1 Attachment(s)
Don,
It goes on a thermo switch just below where the large black bellows connects. Picture show it all. |
Yup, that looks like the one. Do you know if there is a clamp of some sort on the hose to keep it there?
I'm guessing your pic is with the engine out of the car - or are you just very clever with a mirror? Thanks Thomas |
I have never seen a clamp on this hose, and this is the second Motronics car I have had.
BTW- The engine is in the car - just a small camera! |
| All times are GMT -8. The time now is 01:23 PM. |
