Lower ball joint nut, breaking torque
Hi Guys,
I have been working on the front suspension of my 84 3.2. I bought the Pelican tool for the ball joint nut. It says for install only. On the box, it says Sir Tools. I think they make good stuff. I engaged the tool and held it in place with a floor jack that lifted the suspension just a bit. Then I put a 4-foot pipe on my 1/2' ratchet and pulled. It only took maybe 50 pounds of pull before I heard a pop, like a small gunshot, and then the nut was pretty much finger loose. No big deal at all. Just so you know. I have heard other way, including pipe wrench. I have heard the Sir tool does not work. It works, but you have to ensure powerful contanct before you apply powerful torque. Good luck, Dave
Dave McKenzie 1984 Carrera 3.2 1984 928S Automatic 2001 996TT |
Reiver
I used the tool with a 450 lb. air impact wrench to take it off...zip, off. Tool was fine.
Counted the threads prior and used the same wrench to put the new one back on...zip...on.
De Oppresso Liber Strength and Honor 5th Legion |
