OCPO
Storage Man's Avatar
86 Brake Lights come on late..adjustment anywhere?
Have to almost stomp on the brake pedal to get the lights on.
Was thinking the sensor should be on the pedal shaft but can't find it in the Bently manual.
2018 X5
86 911 Targa 3.2
80 Mercedes 450SL
2006 530xi BillyBoat/H&R's....gone
Old 05-11-2014, 06:05 AM
Brew Master
cabmandone's Avatar
Aren't they located at the brake master cylinder in the trunk? IIRC that's where the sending unit is in my 85.
Old 05-11-2014, 06:26 AM
tailwind22's Avatar
There are two pressure activated switches located on the master cylinder. I had no brake lights on my 88 and just replaced both. It solved the problem but they are tough to get to and it was a time consuming process. I have to believe yours are in the process of going bad, thus behaving like they are.
73 914-6 GT tribute, 2.7L twin plug
23 911 w/aero kit
07 GT3 RS Pumpkin
Old 05-11-2014, 06:30 AM
kjchristopher's Avatar
Mine did that when the sensors were failing. Bought two from out host and replaced in about twenty minutes. Super easy with the correct offset wrench, which I happened to have in an toolbox full of my late grandfather's tools.
Do a search on replacing the brakelight switch and you'll see plenty of info.
Old 05-11-2014, 06:39 AM
p911dad's Avatar
+1 And, I didn't need to bleed the system, just topped up the lost fluid. Make sure to place rags under the master cylinder to soak up the small amount of brake fluid that will leak out. I put a bit of Teflon tape on the brake switch threads to make it leak proof.
Old 05-11-2014, 08:30 AM
OCPO
Offset wrench?
Anyone have a part number?
What I see is $129.00ea......
2018 X5
86 911 Targa 3.2
80 Mercedes 450SL
Old 05-11-2014, 08:58 AM
Member 911 Anonymous
DRACO A5OG's Avatar
You really do not need any special tools just remove some of the fresh air components from the trunk area to gain easier access to the rear switch, for installation the rear one, it just needs to be snug then 1/4 turn for torque, the new switches come with a crush washer.
Here, I must recommend OEM from Porsche, aftermarket ones just do not hold up as well. Sorry Wayne. I think you can request OEM from our host too, just call them.
For me, anytime I open the brake lines for whatever reason, I like to press the brake pedal in about 2 inches just to be on the cautious side, you can use a 2X4 and slide the seat up, then crack open the switches, the front one I used a deep socket the rear just a box wrench. It is pretty straight forward but access to the rear is very tight.
Another OCD thing is, I like to drip some brake fluid on the new switches inlet, just to make sure an absolute less chance of any air in the system.
Hope that helps.
Jim
'85 Carrera Targa
PCA/POC
Old 05-11-2014, 09:14 AM
I changed both of them too when someone pulled up next to me and told me I don't have brake lights. When I checked them that night sure enough light around town brake pedal pressure didn't turn them on and only harder pedal pressure turned them on.
I got them from a Porsche dealer and they cost a little less than they do here. Also, the ones from here are silver cadmium or zinc plated and the ones from the dealer are gold cad plated like most other porsche parts and look higher quality.
I wet them with brake fluid before installing them and bled the brakes afterward to get any tiny air bubbles out of the master cylinder.. and last I checked the brake lights work with light pedal pressure now.
Old 05-11-2014, 10:56 AM
wayner's Avatar
Is there a microswitch for the pedal that we can use, perhaps form a later car?
I've wondered if light break pressure in traffic actually has enough pressure to activate the ones on the master cylinder or not?
SOLD - 914 wide body hot rod
Old 05-11-2014, 11:12 AM
OCPO
Hope that helps.
Jim
Hey Jim, thanks.
Happen to have he part number I am looking for?
Are the $129.00ea?
2018 X5
86 911 Targa 3.2
80 Mercedes 450SL
Old 05-11-2014, 01:21 PM
OCPO
This is what I'm trying to avoid. Mild braking is nada, firm braking they come on. Might be on the cusp of needing them replaced but not into spending $260 for a set right now.
2018 X5
86 911 Targa 3.2
80 Mercedes 450SL
Old 05-11-2014, 01:23 PM
ROW '78 911 Targa
timmy2's Avatar
113945515H is the switch number.
Pelican has them from Porsche for $20 each. ATE are $15 each.
Pelican Parts - European Automotive Parts and Accessories - Porsche • BMW • Mercedes • Volkswagen • Audi • Saab • Volvo • MINI
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 05-11-2014, 01:34 PM
OCPO
Thanks timmy2. Well that's a lot better....
I'm assuming I need two of these and some brake fluid.
Any break fluid from our sponsor?
2018 X5
86 911 Targa 3.2
80 Mercedes 450SL
Old 05-11-2014, 01:41 PM
ROW '78 911 Targa
timmy2's Avatar
The part number also cross references to VW.
For brake fluid I use the ATE (if it is still available).
Dennis
Old 05-11-2014, 01:53 PM
Rescuer of old cars
Arne2's Avatar
Plenty of threads on adding a mechanical switch. Lots of us have done it. Here's one:
Safer stop lights
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 05-11-2014, 01:59 PM
OCPO
I read someone used Teflon tape to resell these on instal, or are the crush washers for that?
2018 X5
86 911 Targa 3.2
80 Mercedes 450SL
Old 05-11-2014, 02:56 PM
Originally Posted by Storage Man View Post
Offset wrench?
Something like this:
Should be able to find it in the correct size for cheap.
Old 05-11-2014, 02:59 PM
DRACO A5OG's Avatar
No Teflon needed, just make sure 1/4 turn past snug. oh yeah, go in straight. :-)
Don't worry it is not that complicated, just tight a space for the back ones. ATE Gold, would be best for our cars. Blue stains but the same. I doubt you will need any but better safe then sorry. Plus you may want to do a quick flush anyways. While you are in there. Remember if you do the helper method on the pedal, DO NOT GO ALL THE WAY DOWN TO THE FLOOR BOARD, use a block of wood to prevent dropping the pedal to the floor, it could damage the MC.
'85 Carrera Targa
PCA/POC
Old 05-11-2014, 03:36 PM
OCPO
Thanks Jim. I have a helper.
Dumb question but here goes: Pedal pushed down 2" before during or after removal of the old part.
2018 X5
86 911 Targa 3.2
80 Mercedes 450SL
Old 05-11-2014, 03:53 PM
OCPO
Thanks chRis.
What size did you use to get these off.
2018 X5
86 911 Targa 3.2
80 Mercedes 450SL
Old 05-11-2014, 04:47 PM
