single post lift
Hello- This is a movable single post lift that will raise 6000 lbs to over 6 feet. It rolls around like a pallet jack, and would free up floor space that is lost if you were to install a fixed 2 or 4 post lift. Does anyone have any experience with one of these? Thanks
Old 03-04-2011, 05:50 AM
super9064's Avatar
This is mine, its securely bolted to the floor, if I do not have the car balanced so that the weight is evenly distributed, it will bind. I personally would feel uncomfortable with a mobile lift. See my thread...
How to fit four cars in a two car garage.
Old 03-04-2011, 06:14 AM
Make My Day
wowzer911's Avatar
I'll be purchasing a lift in the near future, and this looks appealing to me....would also like to hear if anyone has experience with these.
74 911S Targa ROW
Building Designer/Business Owner
Old 03-05-2011, 11:10 AM
single post lift
I am seriously interested in this lift- clearly it is intended for occasional hobby use, not day in day out service work. The base measures 3'-6.5" toe to toe-not really robust, so you will have to spend some time getting the load balanced fore to aft. In addition, I would use at least 2 tall saftey stands for my own peace of mind. But it would work well for my other uses of the shop space, since a fixed post lift would be in the way much of the time. Here is another view with a car up in the air. Has anyone out there used on of these? Thanks
Old 03-06-2011, 07:43 AM
80-911SC's Avatar
You could not use this for a Parking lift as the four car into a two car post shows ....
But for what most of us on this board would use it for ... it looks about right ...
Our car weighs about half the rating, which is about half the stress or less (usual rating is half of tested max or less) ...
But for tires ... brakes ... cleaning ... and engine drops looks like it was made for it
Old 03-06-2011, 03:01 PM
82 SC's Avatar
Did anyone actually get this portable lift? Will be getting lift of some sort this coming year when I get the garage built and this one or one similar would be handy instead of a fixed one.
1982 SC "Spooky"
1961 VW Single cab truck
1966 VW Deluxe Hard top
Old 11-27-2014, 04:43 AM
Eng-o-neer
Tremelune's Avatar
I've started a fairly detailed thread on the Garage Journal about these. Not a lot of info is out there:
Portable, pallet-jack-style single post lifts (Mobileman, et al) - The Garage Journal Board
I spoke with a salesman at Eagle Equipment about their Mobileman, and he said he would put me in touch with some of the people they recently sold one to.
Single-post lifts are spooky, but I don't see why the steel would fail any more readily than on some jack stand if you stay within its rating. Famous last words?
Old 11-27-2014, 08:49 AM
The steel on those things doesn't bother me, but the quality of the weld joints does...
Old 11-27-2014, 09:07 AM
faverymi's Avatar
I work out of a 2 post lift that is high quality and properly installed.
Every so often I get some OH SHEET moments when the 911 teeters because of the weight being in the rear.
I can't imagine the rocking you will get out of a 1 post lift. And once is installed and you own it, definitely too late.
I would be interested to hear from actual owner of this lift.
RSA Pinky Helga Turtle
Carrera Luigi CDtdi
Old 11-27-2014, 09:13 AM
I used one once and it seemed fine, but I opted for a 2 post lift as the under car access is much, much better and I never looked back! I was worried about the loss of space, but compared to the ease of use and accessibility, I don't even think about!
Old 11-27-2014, 10:02 AM
theiceman's Avatar
i have a very very compact one post lift .. for short i call it a jack
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 11-27-2014, 11:03 AM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
If you need the floor space...perhaps a table stlye lift is more up your alley.
Do a check on Jack Osen's lift....very neat install...invisible unless in use.
Bob
Bob Hutson
Old 11-27-2014, 01:09 PM
Eng-o-neer
Tremelune's Avatar
This lift is not installed--it has wheels.
Old 11-27-2014, 07:36 PM
I almost bought one like that. The brand was Unic. Here's a video of one in operation, https://www.youtube.com/watch?v=1sIc1BS0BjM&noredirect=1
The one I found was at a commercial garage that had three bays but only two of the bays had doors. They would pull a car into one bay, slide the lift under it and raise it up a foot or two. Then they would simply push the car while it was on the lift into the bay that didn't have a door and work on the car - very clever. The problem with that lift for me is that it takes up a lot of space. I ended with a used Hercules pneumatic lift, Vehicle Lifts - Herkules K900 Lift. When I'm not using it, I park my car on top of it.
1980 911SC Targa
1990 S2 Cabrio (sold)
2004 C4S (sold)
2006 Boxster (sold)
Old 11-28-2014, 05:12 AM
82 SC's Avatar
Montauk that video is the one I am looking at. I will be building a decent size garage and really don't want to put a permanent one blocking my floor space, I will be storing a few campers in the garage and could move this lift under one to get it out of the way for other projects. Still leaning toward a 2 poster but a 2 poster will have to be almost center of my building when permanently mounted. With this lift I could vary it to either side of the garage depending on height of the vehicle, in my case a short 911 and tall VW bus. Still on the fence and it seems to be hard finding someone with actual experience with this one poster style lift
1982 SC "Spooky"
Old 11-28-2014, 07:16 AM
82 SC's Avatar
Single Post Lift - YouTube Seems really stable. This one is not the on I am looking at.
Thoughts?
1982 SC "Spooky"
Old 11-28-2014, 07:31 AM
82 SC's Avatar
Ok sorry about the posts but this video just might have sold me on a single lift
http://youtu.be/lgPGl3ra9BY
1982 SC "Spooky"
Old 11-28-2014, 07:43 AM
