Eng-o-neer
Tremelune's Avatar
How do I get this dead pedal screw out of the wheel well??
So. This car had a set of aluminum Rennline pedals that I pulled out. The last screw was extraordinarily troublesome, to the point where I took a cutting wheel to it to get it out.
Now I'm left with the shaft of the screw (which is turning freely) lodged in my wheel well. It really feels like there's a nut on the other side of it, but I cannot for the life of me figure out how I can get access to it. I'm scared to push it in, out of fear that it will rattle for a decade. Thoughts?
Old 11-29-2014, 09:30 AM
I have a repro RSR dead pedal, and have yet to drill holes in the car to fit it...
But I'm pretty sure that there's nothing to push that screw into, that the other end of that is protruding from the sheet metal in the wheel well. Maybe under a bunch of underseal or silicon...
'77 S with '78 930 power and a few other things.
Old 11-29-2014, 11:53 AM
jittsl's Avatar
Targa or Coupe? If it's a coupe it is like sought said. If it's a targa, I'm not sure but there may be a reinforcing plate that separates the inner from the fender liner. In any case, how about just glueing it in with some JB Weld and then grinding it flush?
Laurence
1998 Specbox racer / 1998 Boxster / 1984 RSR tribute
1970 911E Coupe / 1970 911E "speedster" / 1969 912 Targa
1963 356B T6 Coupe / 1962 356B T6 Cabriolet
Current projects - 1955 356 pre-a Speedster / 1964 356C
Old 11-29-2014, 03:06 PM
MBAtarga's Avatar
vise grips, rotate and pull (yank!)
Mark
'83 SC Targa - since 5/5/2001
Old 11-29-2014, 03:11 PM
porsche boy's Avatar
So there is no rattle issue, I think weld / glue as jittsl recommends then grind flat. Save the pain and agony of messing around with it
Old 11-29-2014, 03:15 PM
I don't think you can get a nut on the back side of that. It may be spinning freely because the hole is stripped. I would try the vice grips with a screwdriver under the vice grips to try to pull it out of the hole.
Tom Feeney
1970 911 T
1973 911 T
Looking for engine 6103643
Old 11-29-2014, 03:38 PM
Also, if you want to get rid of the pedals let me know.
Tom Feeney
1970 911 T
1973 911 T
Old 11-29-2014, 03:50 PM
I enlarged your photo and it almost looks like you have a machine screw tapped into a screw insert. If so, maybe the threaded portion of the insert broke loose and that's what's spinning. Can you tell if an insert has been put into the sheet metal?
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 11-29-2014, 04:16 PM
irl irl is offline
irl's Avatar
Send a message via AIM to irl
That is a hollow cavity. Grab a vice grip and bend back and forth, its just not rethreading back out.
79 SC unmolested
75 911 backdated RSR widebody
71 911T having fun skinny
63 356 outlaw frustrating purists
25 GTS
Old 11-29-2014, 05:00 PM
Eng-o-neer
Tremelune's Avatar
A photo from just behind the front left tire. I have no idea how I missed this. Sheesh.
Old 12-05-2014, 08:16 PM
