pls identify this dash.
will this dash fit an 88 911?http://forums.pelicanparts.com/uploa...1417665916.jpg
http://forums.pelicanparts.com/uploa...1417665979.jpg |
Looks like my '86. Check the PET for the '86 and '88 to see if it's the same part number.
Johan |
It's certainly for an 86, but I believe the 86~89 were all the same. You selling?
Can you check if thy have mounting holes at both ends just like what is pictured below. If so, that might be for a 964 89-94 dashboard. Otherwise, its 86-89.
http://forums.pelicanparts.com/uploa...1417706025.jpg |
yes its the same
I am not 100% but mine (86-89) did not have mounting holes at the end caps and braces upfront like yours. So my wild guess is its for a 964 but I could be wrong.
http://forums.pelicanparts.com/uploa...1417729064.jpg Here is what I took off on my 86 it has been replaced with the same (without mounting holes at the end caps) as well as braces upfront as what yours have. http://forums.pelicanparts.com/uploa...1417729291.jpg http://forums.pelicanparts.com/uploa...1417729308.jpg http://forums.pelicanparts.com/uploa...1417729319.jpg |
| All times are GMT -8. The time now is 09:39 PM. |
