What does a potentiometer look like
Just fitted the headlight switch and while looking at the wiring diagram there is a potentiometer at E20.
Does any one know What it looks like ? Where to get one ? Does it need to be there?
project 1976 911 targa everyday drive 1995 318i BMW wifes car 2001 c200 kompressor coupe spare 2006 mazda bravo ute |
A potentiometer is a variable resistor - usually the kind of thing used to vary the illumination on dash lights or a volume control. Nearly always a rotary control. You can get all sorts and shapes and sizes though. The diagram suggests that this varies the brightness of the dash lights. You will have to choose a potentiometer based on total resistance. It is used, essentially, to vary the voltage output.
Someone will know what resistance range the potentiometer should have.... I hope that helps a little. Cheers, Neil |
Should be inside the light switch. Turn clockwise to brighten CCW to dim.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
Neil is correct on the resistance being important...but missed the current factor.
You can get very small, lightweight pots...but they will burn out very quickly if they cannot handle the current flowing through them. As Pete said...the pot should be inside the light switch in the dash. Best to get a stock replacement one rather than experiment with after market ones. Also...if you are changing over to LEDs....you might need to add a resistor to the circuit to get it to work (LEDs draw very little current...so the voltage stays almost the same throughout the pot's range). There are also solid state gimmicks to do the same job...they "chop" the voltage into small timed spurts to get the same effect as reducing the regular pots. The drawback of the solid state ones...sometimes introduce noise into the wiring...and can interfere with the radio...or even the ignition. Bob
Bob Hutson |
Ok thanks
Makes sense being in the headlight switch, just couldn't get that from the diagram.
Should be all good thanks again to Pelican
Uncertifiable!!!
HawgRyder,,
Any idea what resistance would be required to dim the LED instrument lights? Johan
🇨🇦 The True North Strong and Free 🇨🇦 Living well is life's best revenge- George Herbert (1593-1633) 2006 C2S, 2024 WRX GT, 911 hot rods on Pelican…. Evolution of a Carrera RST, and Sweet Transplant |
Carmagic.us
Testing some Instrument LED Cheers Engelbert
For BA7s Dash LED, and External Marker LED go to carmagic.us - Now Luftgekühlt Emblems |
