Super Moderator
cstreit's Avatar
Pls help: Adjustiong CO on 930
Gang,
I had to replace the mixture screw on the 930 and dur to some slight changes and dissassembly, I need to reset the CO on the car...
First: I need to set it for low emissions for the pollution test.
Second: I need to set it for otimum running.
Please help! I don't have a GASTESTER and need to get it reasonably close but despite 3-4 hours of tinkering and all the reading I can find, I'm still clueless.
I have 30 days to pass emissions and need to at least get close.
THanks,
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 10-14-2002, 12:46 PM
I think you are going to have to buy or borrow a gastester. It would be very hard to do it with out one.
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 10-14-2002, 05:51 PM
get it hot, unplug the oxygen sensor, clamp the airpump hose between the pump and the gulp valve, turn the CO adjuster counterclockwise a bit at a time, until you hear the idle speed decrease somewhat. leaning the idle mix eventually causes the idle speed to slow, somewhere around 2% or less. keep leaning a bit more, as long as the idle doesn't get too rough. then plug the oxygen sensor back in, and unclamp the air pump. the oxy sensor will put the mixture where it wants to. there must be a shop near you that will do a sniff test for cheap or free.
206 637 4071
Old 10-14-2002, 06:29 PM
Super Moderator
cstreit's Avatar
THis is a Euro 930, I don't think it HAS an oxygen sensor, does it? Definitely no air pump... Mechanical injection here...
Now, you're saying lean it out untill just before it runs rough? I was told to increase the mixture richness untill the idle doesn't climb any, then back it off slightly.. AUGH..
Well I made an appointment to a guy with a tester... I'll have him set it once for emmissions, then set it back for smooth running, they're definitely NOT the same setting
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 10-14-2002, 07:09 PM
The Gunson gastester is $140 shipped. I think it is well worth the price
Dean
Old 10-14-2002, 08:04 PM
Super Moderator
cstreit's Avatar
Is there a US distributor?
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 10-14-2002, 08:17 PM
Yes do a search on Gunson gastester. He is in FL
Dean
Old 10-15-2002, 02:57 AM
Seven-Seven's Avatar
Chris--
Try this:
http://www.aep.bigstep.com/item.html?PRID=26103
and/or this:
http://www.aep.bigstep.com/item.html?PRID=26102
Carlton
'77 911S Targa w/3.0
Old 10-15-2002, 03:44 AM
Super Moderator
cstreit's Avatar
Gracias. He cost of one session with my Co guy will cover this... Think I'll take the dive...
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 10-15-2002, 05:57 AM
