-   -   Open circuit on rotors (http://forums.pelicanparts.com/porsche-911-technical-forum/841867-open-circuit-rotors.html)
rockreid 12-08-2014 06:17 AM
73.5 Targa-
OK, so I've ordered the NAPA rotor with no resistor and we'll see if finally my no spark condition is resolved. I've tried everything else. My multimeter indicates an open circuit between the center pin area contact and the cap contact point on both my new PP-supplied RPM limiting rotor and the original vintage stock rotor. Both are wax potted which to me indicates they both have a resistor inside.
Really, if this indeed does resolve my situation, since I bought the MSD from here at PP they really should indicate somewhere that you need to also purchase a non-resistor rotor as well to prevent this sort of failure. This has been a good 2 months of wasted time and effort.
wwest 12-08-2014 07:42 AM
There is NEVER an electrical contact across the rotor, HV jumps just like spark gap.
T77911S 12-08-2014 07:53 AM
i have run MSD in 2 cars over the past 12 yrs and never had a BOSCH rotor go bad.
rockreid 12-08-2014 10:08 AM
wait- are you saying that from the center of the rotor to the tip should be open? There are write-ups on this forum stressing the need to remove any resistor in these rotors being used with MSD.
http://forums.pelicanparts.com/porsche-911-technical-forum/596559-msd-rotor-modification-detail.html
From the center contact on the rotor to its tip I am getting open circuit. So this is normal condition?
rockreid 12-08-2014 02:13 PM
according to further research I should NOT be getting an open circuit on the rotor as measured from center contact to edge contact:
Inside a Ignition Bits
http://www.vwdcqinc.org.au/vwdcqimag...enedrotor4.jpg
.. I should be getting some sort of resistance if my rotor's resistor is OK.
wwest 12-08-2014 06:50 PM
Yes, the rotor tip is not designed to make actual physical metal to metal contact with the spark plug connector post.
911pcars 12-08-2014 08:42 PM
On early 911 distributors, one could replace the rpm-limiting rotor with a solid rotor from a VW. Not sure about later distributors. Anyone ever substituted all the ignition parts (rotor, spark plugs, SP cable and end connectors) with non-resistance versions and lived to tell us about the results?
Sherwood
T77911S 12-09-2014 04:07 AM
it should not be an open but it will have high resistance.
i dont know what type of MM you are using but if you have to select the ohms scale to use and you use a low scale like 0-100, it will show an open.
i dont remember what the resistance is.
