Slippery Slope Victim
Need a Carrera Wiring Expert
In my quest to clean up and correct any wiring defeciencies on the '85 M491 I have run into 2 questionble things.
1st... the easy one.....see below. Can anyone ID the small single wire Molex type connector?? ![]() ![]() ![]() 2nd...there is a lone solid black wire, not bundled, loose, coming off the bottom of the 4th fuse from the firewall. It is position 2 on the second fuse block. The chart says it is for all the interior lights. The problem is the wire runs to a solid black wire in tandem with a brown ground wire. It also has a homemade splice in between the points that it connects back into the harness. My question is what should the proper stock wiring look like for the interior lighting circuit?
MikeČ 1985 M491 Last edited by NY65912; 12-08-2014 at 04:32 PM.. |
I think I got my answers from this thread.
luggage compartment light/Inside lights/clock wiring issue BTW I Google searched it. Sometimes the BBS search is a PITA. I am most concerned at the termination of the black wire on the left (driver's side) trunk ibehind the firewall. TIA
MikeČ 1985 M491 Last edited by NY65912; 12-09-2014 at 08:34 AM.. |
