-   -   Why weak starting at times? (http://forums.pelicanparts.com/porsche-911-technical-forum/842201-why-weak-starting-times.html)
DRACO A5OG 12-11-2014 11:24 PM
Hey Karl,
Not for nutin, but consider getting a battery tender with a maintenance cycle like a C-Tek 3300. Your New Battery will last longer and it will insure you have 12.6+ volts prior to start up.
The maintenance cycle is important so it can de-sulfate the battery for you.
Jim
patz 12-12-2014 10:44 AM
Glad it worked out.....BUT a decent volt meter is a must for old Porsches.
Discseven 12-12-2014 03:43 PM
Originally Posted by DRACO A5OG (Post 8392830)
Hey Karl,
Jim
Good suggestion Jim. TY. Great idea for 911's hibernating for winter--but then guys in winterland probably know this gizmo already. Digging for more batt intel, came upon "how to kill a battery"...:
  • Batteries sit too long between charges. As little as 24 hours in hot weather and several days in cooler weather.
  • Battery is stored without some type of energy input.
  • "Deep cycling" an engine starting battery. Remember these batteries can't stand deep discharge.
  • Undercharging of a battery to only 90% of capacity will allow sulfation of the battery using the 10% of battery chemistry not reactivated by the incompleted charging cycle.
  • Heat of 100 plus F., increases internal discharge. As temperatures increase so does internal discharge. A new fully charged battery left sitting 24 hours a day at 110 degrees F for 30 days would most likely not start an engine.
  • Low electrolyte level - battery plates exposed to air will immediately sulfate.
  • Incorrect charging levels and settings. Most cheap battery chargers can do more harm than good. See the section on battery charging.
  • Cold weather is also hard on the battery. The chemistry does not make the same amount of energy as a warm battery. A deeply discharged battery can freeze solid in sub zero weather.
  • Parasitic drain is a load put on a battery with the key off. More info on parasitic drain will follow in this document.
More complete info at:
Battery Basics: A Layman's Guide to Batte | BatteryStuff Articles
Discseven 12-12-2014 03:46 PM
Thanks PATZ. Got small, non-pro VM. Works fine. How's winter swell off Newport?!
