-   -   2.7s cis upgrade - suggestions (http://forums.pelicanparts.com/porsche-911-technical-forum/842296-2-7s-cis-upgrade-suggestions.html)
advtracing 12-10-2014 09:32 PM
I have a 1976s R-gruppe car (990kgs) , i ripped the cis off last year and went for 40 ida's . the car has been running well but the lower end was warn and is showing issues and oil burn.
Time to rebuild , so i need a few solid suggestions for upgrade spec's.
thinking 2.7 case , 930 oil pump , std rods , je pistons and cylinders bumping to 9.5.1, cams ? , plus ..
http://forums.pelicanparts.com/uploa...1418279460.jpg
http://forums.pelicanparts.com/uploa...1418279515.jpg
Porboynz 12-10-2014 11:13 PM
1992 3.6 PORSCHE ENGINE 3.6 1992 | Trade Me
JeremyD 12-11-2014 04:22 AM
Originally Posted by Porboynz (Post 8391240)
Absolutely!
advtracing 12-11-2014 08:58 AM
oh come on , no way . lets keep period . must use the 2.7 case
Jack Stands 12-11-2014 10:24 AM
Case savers and Supertec head studs to make it live. A modern EFI system (Motec, etc.) using PMO throttle bodies would also be nice. Coil on plug technology?
Speed costs money, how fast do you want to go?
Charles Freeborn 12-11-2014 11:05 AM
With what you've outlined, the heads are going to be the flow restriction. You're looking at port 'n polish. Plus, depending on what octane you've got available, @9.5:1 you're at the outer limit for single plugs. You're heading into some serious money here. Run the numbers on a 3.2 swap, and consider putting the 2.7 in storage for a fussy future buyer.
-C
al lkosmal 12-11-2014 11:35 AM
If you want a great old-school hot rod motor.....A 2.7S with weber 40's, 9.5:1 JE pistons, E-cams (or equiv), SSIs and a sport muffler.............is a great 911 single-plug, hot rod, street motor. You will like it. I am building one as we speak.
regards,
Al
PS: take that same recipe, but use EFI/ITBs..........better yet.
PS:
Chris_chch 12-11-2014 12:03 PM
WAAAAYYYYY off topic, but who did you source your bumpers from? Is there anyone in NZ making them? Great looking car!
advtracing 12-11-2014 02:08 PM
regards,
Al
PS:
this is what i mean , old school , i am running factory headers , dansk muffler , love the carbs (can't beat the sound ) E cams ? thats mild ?
no chance on them in nz , brought them in from CA as with most stuff
