-   -   Clean injectors (http://forums.pelicanparts.com/porsche-911-technical-forum/84254-clean-injectors.html)
79targa 10-15-2002 08:40 AM
Clean injectors
Is there any particular injector cleaner additive that should be used with the mechanical injectors? Can I use the same stuff that I use on more modern injectors (BG40 from BG products). Do the mechanicals need additive cleaning more/less frequently?
for now Dr. CS
efhughes3 10-15-2002 09:48 AM
Do a search on Techron, and you'll see a lot of posts on its merits.
