Cam Cover removal
Well I am on my way to rebuilding the engine in my 1976 911, 2.7L. I have stumbled on a minor roadblock. I have the chain tensioners and sprockets out, as well as the washers. I am now to the cam covers. Wayne's book says to pry these out. So I have tried using needle noses pliers, a small screwdriver which makes me nervous but they are not moving. Can anyone suggest a good way to remove these. Picture shows the cover I am referring to. Thanks.
TC
Tom 1987 911 Targa 1987 944 Turbo 1976 911S 1973 Mustang Mach 1 351C |
Remove the chain guides and all the securing hardware for the chain boxes, pull each one slightly outward and the caps should pop off.
The Cap'n |
Fleabit peanut monkey
You have the five or so bolts out that hold the chain box to the case? You must because you can't really miss them.
Get a lead or plastic hammer and tippy-tap. You can tell by the sound if all the fasteners are out. If fasteners are still in place there will be a resounding "eff you", I ain't moving.
1981 911SC Targa |
Are you talking about the flange that holds the cam in place? Just grab the end of the cam and pull it out.
The Dude abides...
I used a few plastic wall anchors to grasp the flange to work them out and unseat the o-rings.
Steve '03 Carrera 4S |
screwdriver in from behind and pop it loose. you can see the top edge from behind. normally done with the upper valve covers off, but you can get at the left side through the spark plug hole, but the right side cover needs to be off. lever against the cam tower and out it comes.
https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071 Last edited by john walker's workshop; 12-17-2014 at 06:31 AM.. |
The Dude abides...
I went about using a screwdriver initially, but was finding that I couldn't get a good 'hold' on the flange edge and could see myself marring the edge of the keeper.
I have seen reference made to the screwdriver technique as John describes, so it's really up to you. Quote:
Try this one........
Tony |
if you put a tiny mark on the back of the retainer by using a large screwdriver, it doesn't really matter, as that area does not seal against anything, obviously.
Thanks for the input. I was able to pull the cover out slightly and I slid a piece of rope in behind the cover, pushed back on the timing chaine cover and it popped right out. I tried the plastic wall anchors and the anchors kept pulling out of the holes. Onto pulling the heads.
