7-31 R&P for a 915
Hello everyone. I have this ring and pinion. It is a 7-31. Can anyone tell me if it is for a 915 or a 901?
John
Old 02-01-2015, 02:57 PM
gearhead
901. If you look on the parts closely there should be 11 digit part numbers and a pro date (2 digit month and 2 digit year with a logo between them).
Old 02-01-2015, 04:14 PM
I will look for those numbers. But this looks like a 901 R&P?
John
Old 02-01-2015, 06:49 PM
Racer
winders's Avatar
John
John,
If Matt Monson says it is a 901 part, and he did, it is a 901 part.....
Old 02-01-2015, 06:58 PM
I understand. I will confirm with the numbers he spoke of.
Thanks for the help,
John
Old 02-01-2015, 07:16 PM
gearhead
See the difference in the nut end of the shaft?
FVD Brombacher Online Shop - 91530291117 - ring and pinion 8:31 (for 915 gear box) -
Old 02-01-2015, 07:19 PM
the roller bearing is an instant giveaway.
206 637 4071
Old 02-01-2015, 07:32 PM
I can see what you are talking about. The date is 8 69. Aug 1969.
Also I see the difference in the threaded end of the pinion shaft, and note the roller bearing.
Thanks for the help guys.
John
Old 02-01-2015, 07:55 PM
