P Car Addict
klober23's Avatar
Longhood 911 S - Is there rubber between the fender chrome and the car?
Putting some S chrome trim back on a longhood. The fender lip chrome I have is used and it looks like there use to be rubber between the trim and car originally? The diagram I have shows the chrome screwing straight to the fender. Please advise. Thanks
Old 12-23-2014, 06:41 PM
Stophos's Avatar
I have removed the fender surrounds molding on a few pretty original 69's and there wasn't any rubber.
Old 12-23-2014, 06:52 PM
Send a message via Yahoo to mobius911
At least for 69-73 the trim gets a strip of narrow beading around the perimeter. It goes on the front and rear bumpers as well as the top edge of the side deco. There is a square slot in the trim that accepts it. Does yours have the slot? The part number for the plastic beading is 999.911.198.40.
Jeff Jensen
1973 911
Old 12-23-2014, 09:34 PM
P Car Addict
klober23's Avatar
Thanks gents. I will have to check tomorrow but I know the rocker chrome did have the rubber bead..although these pieces were new as was the rubber. The rubber that appeared to be on the fender trim looked to be glued. I do know the rubber bead your are talking about and will check it for accepting this, but I don't think it does.
Thanks again for the response.
Old 12-23-2014, 09:37 PM
ahead of the curve
Jeff Burger's Avatar
+ 1 - I never seen it on the wheel arch trim
19 Carrera T - MPS member
92 C2 SR coupe M491/ 3.8 look- manual
92 C2 SR coupe cobolt blue- manual
73 914 1.7 (?) AG -a solid project looking 4 a sugar daddy
73.5 T gemini blue SR coupe sold 8/22 my last long hood gone
Old 12-24-2014, 06:25 AM
My bad. I was commenting on the bumper and rocker trim, not the wheel arch trim. I agree with Jeff Burger.
Jeff Jensen
1973 911
Old 12-24-2014, 09:00 AM
dhrcr911s's Avatar
Wasn't any on my 67S
I stand corrected, see picture below.
SWB 911S 1967 307653S in my fathers garage now
LWB 911T 1971 9111120264 Back in my garage after a lenghty stay in Oregon
Old 12-24-2014, 09:04 AM
dhrcr911s's Avatar
This is how the S got put back together. I did put a small rubber trim pc between the bumper and aluminum rub strip. My earlier post is incorrect.
Old 12-24-2014, 09:07 AM
Ayo Irpin, Ukraine!
70SATMan's Avatar
I think the confusion stems from you labeling the wheel arch trim as "S".
The wheel arch trim was optional for all models and was not a standard "S" item. I agree with others, no rubber trim listed on the wheel arch moulding however, there has in the past been discussions about whether a double sided tape was used underneath similar to the LWB rocker moldings.
Harmlessly passing gas in the grassland away;
Only dimly aware of a certain smell in the air
Old 12-24-2014, 10:01 AM
My original wheel arch trim had what looked like a black sealing material on the surface that was in contact with fender only. It was not a rubber part but appeared to have been brushed on just prior to riveting at fender lip, dries hard and seals out dirt from inside wheel well. I have seen this on trim that was removed. Hope this helps.
Old 12-24-2014, 05:51 PM
P Car Addict
klober23's Avatar
Thanks for the update..I believe this is exactly what I am seeing as well. Appreciate the feedback
Old 12-24-2014, 06:19 PM
