-   -   G50 Gearbox Case - Nut torque specs? (http://forums.pelicanparts.com/porsche-911-technical-forum/843842-g50-gearbox-case-nut-torque-specs.html)
Spenny_b 12-23-2014 10:07 AM
Hey guys,
Tried searching for this but not coming up with much.....calling Matt Monson!
In order to add traction control to the car, I need to mount 4 x Hall Effect wheel speed sensors - no probs there, and for the rear I'm using some of the fixings on the G50-52 box, to secure the mounting brackets.
Does anyone have the torque settings for the M8 case nuts please? I'm using a couple of studs on the diff plate, and one of the studs that joins two parts of the case together, per pic below (it's only at mock-up stage at the moment!):
http://img.photobucket.com/albums/v2...3923C3443E.jpg
I may also replace the tired looking nuts with some fresh ones; if there's also a tightening sequence, I'd be very appreciative.
Spencer.
yelcab1 12-23-2014 11:53 AM
All M8 case nuts are 25Nm.
Spenny_b 12-23-2014 01:14 PM
Thanks Yelcab, wasn't sure if the transmission was the same as the crankcase spec for M8 or whether it was higher.
Cheers
Spencer.
