-   -   Easy Fix - Running Rough & WUR Connection (http://forums.pelicanparts.com/porsche-911-technical-forum/844149-easy-fix-running-rough-wur-connection.html)
vesnyder 12-26-2014 08:55 PM
My '83 SC has been running rough and it was driving me nuts. Had gone through and did a tune-up and it had no effect. Realized that my connection to my WUR was broken and did not make the connection. Finally reconnected the WUR and it solved my problem. Car is running so good I had to take it out and give it an "Italian Tune-up"! The connector is broken and will not stay attached. I did a Mickey Mouse fix but then found the Eagle Day web site (eagleday.com). They have the replacement connectors.
Thought I would share an easy (and inexpensive!) fix to a problem that has been frustrating me.
Paulporsche 12-27-2014 01:36 PM
Are these the 2 way mini connectors?
Bob Kontak 12-27-2014 02:14 PM
Same type that plugs into the AAR, back of air sensor, and freq valve. With the wire clip.
timmy2 12-28-2014 01:08 AM
They are called timer junior connectors and I have/use them for harness building.
I've sold a few kits to members that didn't want to pay the crazy shipping costs others charge. :)
Basically they are fuel injection connectors. Here are 3 styles you can find. I have the original style in the middle, and the one on the right.
The quick release ones on the left are available on Pelican.
http://tapatalk.imageshack.com/v2/14...2c663ea92e.jpg
