-   -   Dyno results -- a 2.8 built by John Gregory (http://forums.pelicanparts.com/porsche-911-technical-forum/84419-dyno-results-2-8-built-john-gregory.html)
dean 10-17-2002 05:57 AM
Wow a 72 year old mechanic building impressive motors! What is in the water down under. Send some up our way.
Have fun
Matt Holcomb 10-17-2002 06:56 AM
John,
I wish that engine was in my car! It belongs to a guy who does a lot of tarmac rallies, and has won many.
John Gregory rebuilt my engine last year, which is a 911/83 with 11.3:1 JE pistons, GE-60 cams, single-plug ignition, EBS racing springs, titanium retainers, and SSIs.
Matt Holcomb
MFIWDP
<b>PRVC</b>
<b>BOHICA</b>
1974 911 Carrera 2.7 RoW<a href="http://www.holscope.com/74Carrera2.7" TARGET="_blank"></a>
1975 Mercedes-Benz 280SE
<a href="http://www.holscope.com/74Carrera2.7" TARGET="_blank">Dedicated Homepage</a>
<a href="http://www.holscope.com/74Carrera2.7/rebuild" TARGET="_blank">Engine Rebuild Homepage</a>
<a href="http://www.cheaterswayside.com/911/gallery.asp?sort=0&userid=127" TARGET="_blank">Porsche Owners Gallery Profile</a>
<a href="http://www.pelicanparts.com/cgi-bin/pmpre/pm.cgi?action=display&login=Matt_Holcomb" TARGET="_blank">Pelican Gallery Profile</a>
HawgRyder 10-17-2002 07:01 AM
Tinton:
Yes there is an old trick to keep detonation down.
Bill Elliot of NASCAR fame came up with a trick on the pistons many years ago.
The basic idea was to cut a series of saw tooth shaped cuts into the side of the piston in the land between the first and second rings.
What this did - as the piston moves up - it forms a rolling wavefront to sweep the gas/air mixture away from the side of the cylider wall.
Detonation is caused by the exploding wavefront hitting a flat or reeflecting surface.
Elliot's affect allowed him to run about 17:1 compression and beat the heck out of all competition for a 1/2 year.
I tried the idea on a formula Ford ...works...sort of....it gave us an edge...but not sure if the mod or the driver was the real cause (we ran 11.5:1 when everyone else was limited by fuel to 9:1)
Bob
Matt Holcomb 10-17-2002 07:13 AM
Bob,
That's interesting. When John Gregory was rebuilding my engine he used a special tool to smoothen all the sharp edges on the pistons. But I don't think this was done to keep detonation down as we had to lower the distributor advance to 28 to prevent detonation, which it did -- completely.
Do you lose power by lowering the distributor advance?
Matt Holcomb
MFIWDP
<b>PRVC</b>
<b>BOHICA</b>
TimT 10-17-2002 12:17 PM
Its important to chamfer all the sharp edges on the piston crown prior to assembling the engine. The sharp edges can become hotspots and contribute to detonation. A few minutes on each piston with a piece of emory or crocus cloth will eliminate the sharp edges.
CamB 10-17-2002 12:23 PM
"Do you lose power with less advance"
Yes, unless the lesser advance is because of twin plug (at least that is what I understand).
Cam
Bobboloo 10-18-2002 12:35 AM
Bob, That's really interesting. Where can I read more?
Bobby
