-   -   Rear Sway Bar Bracket Orientation? (http://forums.pelicanparts.com/porsche-911-technical-forum/844404-rear-sway-bar-bracket-orientation.html)
N882928 12-29-2014 09:18 AM
What is the correct orientation of this rear sway bar bracket when mounting to the body? As you can see, one side of the bracket is taller and has more of a radius. Does this taller side mount inboard or outboard? All of the diagrams I've found don't show this detail and the search did not turn up anything. Your help is appreciated. Thanks.
http://forums.pelicanparts.com/uploa...1419873356.jpg
http://forums.pelicanparts.com/uploa...1419873401.jpg
mreid 12-29-2014 09:38 AM
Looks like a stamping irregularity to me, so either will work.
bkreigsr 12-29-2014 09:41 AM
that being said, on this bracket, I would bolt the heavy end to the captured nut closest to the body.
Bill K
N882928 12-29-2014 10:05 AM
Both brackets (both sides) are the same. I don't see any signs of a double hit or stamping flaws. I think it was designed to be this way. Has anyone installed a stock rear sway bar recently with these later brackets?
Bill, so I take your reply as heavy side in.
N882928 12-30-2014 02:38 PM
Bump. Anyone know this one for sure?
bkreigsr 12-30-2014 04:07 PM
Doesn't make much difference.
Under optimal conditions each bolt will be under an equal amount of stress.
In other words, in the event of a fail, the results be the same regardless of the orientation of the bracket.
Bill K
winders 12-30-2014 04:54 PM
It doesn't matter. It's clamping a big hunk of rubber.....
McLaren-TAG 12-30-2014 04:56 PM
Don't know if it would make a difference, the primary force in that area is the twist along the circumference so as long as they're both oriented as a mirror image I'd imagine it's fine.
I have my car on jackstands at the moment and checked. They're installed with the lip on the inboard. But thinking out loud through this (and I've had two beers) if the force is placed on the bar and transferred to the other wheel to keep the car level as much as possible then there would be "some" squeezing lateral force towards the inside of the vehicle so you'd want the more pronounced lip to be on the outside keeping the bushing in its place.
winders 12-30-2014 05:30 PM
One more time: It doesn't matter. It's clamping a big hunk of rubber.....
McLaren-TAG 12-30-2014 05:36 PM
Why would Porsche go through the trouble of reinforcing one side?
safe 12-31-2014 01:14 AM
Mine is completely flat, no lip at all.
Doesn't matter...
ian c2 12-31-2014 04:32 AM
The heavy sides both face inwards towards one another .
If your car uses collars , the thicker side goes towards the collar .
