Window regulator spline dimensions?
Does anyone know the dimensions of a Porsche manual window regulator spline (the bit the window winder fits onto) and if it has changed at all over the years?
I'm fairly certain it is 16 teeth but would like confirmation that the diameter is 1/2 inch. Finally, is it correct to assume that it shares it's dimensions with a standard VW/Audi spline? |
