1970 clutch cable articulated piece nipple. Help
Does the nipple at the end of the articulated piece butt up against it or does the nipple slip into the pieces channel? Thanks very much.
the split collar goes into a notch at the lip of the bellhousing. looking at the picture, that would be way to the left of where it is now. pull the cable through first and slip on the collar.
https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071 Last edited by john walker's workshop; 01-03-2015 at 07:46 AM.. |
That split collar is now resting on the (articulated piece lip) It will not go into that bellhousing (articulated piece) any further. My concern is that to me it should fit into that piece and not sit on the lip of it. Thanks again.
Well, I just figured it out. As my wife says... you don't look and think..you just look. Thanks for your guidance. Larry
| Tags |
| clutch articulated piece |
