kcope's Avatar
Question Blaupunkt Radio Help
Ok just got my new/old radio today. Its a 1978 Blaupunkt Frankfurt With ARI (whatever that is).
The round connector at the bottom is for external devices, correct?
The spade connector for the power looks easy enough. Anyone have a pic of the speaker connections.
I assume that the smaller spade connection next to the power connector is for a power antenna Correct?
Any help is much appreciated
Ken
Ken Copeland
70 GT6+ KC78784
70 Spit FDU84919
70 GT6+ KC81551 (Ok so I like 70s)
71 Porsche 911T
00 Chevy Pick UP
Old 10-17-2002, 11:34 AM
Ken,
The round multi-pin connector is for an external amplifier, with which you can go stereo,
The radio is a mono as is, with one speaker connection, that is the 2 connectors next to the speaker icon. these are a vertical spade and a small rod: " I. " except the rod is in the middle of the spade height. Older home stereo speakers had the same connectors
the connector on the left top is for an electric antenna. the last one looks like an antenna connector.
the ARI is a system that receives the road condition information broadcast once an hour , or when special driving occurences happen, on main European radio stations. Usually if you listen to a tape, the ARI interrupts the tape while the message is broadcast, or if you have the sound on low, it raises the level for the message.
GeorgeK
Old 10-17-2002, 12:16 PM
kcope's Avatar
It works!!!!!
All right now if I can find The proper connectors I should be all set.
Ken Copeland
70 GT6+ KC78784
70 Spit FDU84919
71 Porsche 911T
00 Chevy Pick UP
Old 10-17-2002, 01:24 PM
kcope's Avatar
By the way Thanks George!!!!!!!!
Ken Copeland
70 GT6+ KC78784
70 Spit FDU84919
71 Porsche 911T
00 Chevy Pick UP
Old 10-17-2002, 03:52 PM
one of gods prototypes
bell's Avatar
if you plan on adding an aftermarket amp i'm sure someone has the schematic on the 6-pin plug for the preamp level outputs.
you will probably notice that the single mono output will not be sufficient for listening while driving.
let us know how iut turns out.
Brought to you by Carl's Jr.
Old 10-17-2002, 04:31 PM
