They would work, Yes.
Using spacers will increase the scrub radius of the front suspension, and may cause some instability if much more than the factory designed alignment spec.
use the longer studs with spacers. I've seen a few of the bolt on type crack.
I've ordered the spacers that I listed above. I'll update when I receive and install them. Thanks gents!
Roch. |
| All times are GMT -8. The time now is 05:08 AM. |
