weber install ????????
putting 40ida on my 3.0sc motor, my question is before the fpr,do I cut the metal end off the oem fuel lines, I know to get rid of the oem fuel filter,and accumulator. thanks for any and all responses
bump
Are you talking about green hard lines from the tunnel? I wouldn't cut them, but there is going to be either some sort of adapter to use them as is or run new lines from the tunnel > filter > pressure regulator.
A few images of hard lines being adapted can be found here: http://forums.pelicanparts.com/porsche-911-technical-forum/809009-6-fuel-line-plan-cis-pmo-carb-conversion.html |
| All times are GMT -8. The time now is 10:03 AM. |
