irl irl is offline
irl's Avatar
Send a message via AIM to irl
PMO fuel gauge adjustment????
So after an engine/ new fuel lines/pierburg install, the car is running but idling pretty high and the the PMO shows no pressure reading. I haven't adjusted the needle valve but I thought I would see an immediate high pressure before I do anything???
79 SC unmolested
75 911 backdated RSR widebody
71 911T having fun skinny
63 356 outlaw frustrating purists
25 GTS
Old 01-06-2015, 06:14 PM
Gordo2's Avatar
Turn The Valve
Your Pierburg is factory pre-set to a certain PSI (~ 5 for low pressure carb configs). Pierburg specs for their various pumps:
http://download.ms-motor-service.com/ximages/pg_pi_0034_en_web.pdf
Looks like you have a recirculation circuit coming from the PMO reg, which is generally acknowledged as a good thing.
Opening the PMO valve allows the fuel to recirculate back to the tank thereby reducing pressure. Good news - it looks like you don't have any blockage on your return line (0 psi indicating the fuel is recirculating to the tank with no back backpressure). Surprised your engine idles at very low pressure.
I use a small washer to turn the valve - play around with it until you get it to 3.5 PSI.
Good luck,
Gordo
Don "Gordo" Gordon
'83 911SC Targa
Old 01-06-2015, 07:02 PM
G50911's Avatar
my 68 doesn't have a return and i just capped it. i get a steady 3 psi. since this disables the valve does anyone know which pierburg pump gives out a constant 3.5? sorry to hijack your thread Siri
1967 911 (Azzuro Thetys) - #308439
1971 911 (PTS Black) - Built 3.6 Sleeper
1989 911 (Grand Prix White) - Cabriolet Bone Stock
Old 01-06-2015, 07:31 PM
irl irl is offline
irl's Avatar
Ok, thanks Gordo. Ill starting cranking it down and watch what happens. Assuming my pump is putting out 5 PSI, I expected the gauge to show a higher PSI and cranking it down would drop the pressure. Also odd that not only is the car idling, its idiling high with the idle screws way down. I do need to adjust the carbs though, they are newly rebuilt as well.
79 SC unmolested
25 GTS
Old 01-06-2015, 08:19 PM
irl irl is offline
irl's Avatar
bump
79 SC unmolested
25 GTS
Old 01-07-2015, 08:49 PM
