Starter clicks, but won't turn over...
Okay so I got my engine in and have everything hooked up that should be in order to start it up. Problem now is when I try and start it all I hear is the starter click and then nothing. Anyone have any ideas as to what could be the culprit?
Here's a pic. I'll try to shoot some better ones later on.
Bob Springer
1978 911 SC (Almost Finished)
http://www.noh2o.com
Old 10-18-2002, 11:38 AM
dickster's Avatar
nice
i'd check the battery first - is it fresh??
Rich
'86 coupe
"there you are"
Old 10-18-2002, 11:53 AM
Sounds like a daead battery. Check voltage. It should read around 12.5. When you turn the key to start, voltage should not drop below about 10.5. Check for good clean connections.
Chuck
1987 911 Targa
1962 C182
"Dirt is permanent. You can move it around, but you can never destroy it."
Old 10-18-2002, 12:03 PM
Battery is good. Just took it in to have it charged and it charged up fully. I also checked connections and everything looked pretty clean and tight. I'm a bit stumped.
Bob Springer
Old 10-18-2002, 12:08 PM
nostatic's Avatar
back in the day, I recall having to crawl under the car (my bug) and bang on either the starter or solenoid when this happened. The technical explanation was it "got hung up".
Old 10-18-2002, 12:10 PM
Does the wiring on my starter look correct?
Bob Springer
Old 10-18-2002, 12:14 PM
marcesq's Avatar
If the battery checks out, and the solenoid still clicks, take a 22mm socket to the fan nut and turn the engine in the CLOCKWISE direction a full turn.
Check ground strap from tranny mount to chassis.
If you still get a clicking jack up the right side (use jack stands of course)and wack the starter with a hammer while someone tries to start the car. If the it still clicks starter is shot.
If it turns over, you might get some more milage out of the starter, but who knows how long.
Good luck.
'94 CMC Firebird Trans Am
'86 951 LS1 (C-2) Gone
'77 911 3.2 (C-1) Gone but not forgotten.
http://www.pelicanparts.com/MotorCity/marcesq1
http://www.youtube.com/user/958Fan#p/u
dickster's Avatar
well the click means you've got power going where it should, so either theres not enough available (bad battery) or theres a bad connection.
check the connects are good, earths etc.
the battery may be charged but that doesn't mean its good - might have a dead cell. swap with a good known one or have it tested.
or (and i doubt it) the starter is playing up.
you can bypass the selonoid by bridging the terminals, but might not be easy in the car.........
Rich
'86 coupe
"there you are"
Old 10-18-2002, 12:15 PM
marcesq's Avatar
Bob:
Can't see the pictures for some reason.
2 wires to the solenoid. One small one on small terminal, and one from the battery. The one from the battery goes on the terminal closest to the tire.
Another possible problem is the 14 pin connector. Unplug and replug a couple of time to insure that the contact is good as there is a wire in there that goes to the solenoid
Old 10-18-2002, 12:20 PM
marcesq,
You might have nailed it with the ground strap, hate to admit it but I pretty sure I don't have the ground strap on. I'll try that and let you know.
Bob Springer
Old 10-18-2002, 12:21 PM
nostatic's Avatar
Originally posted by marcesq
If you still get a clicking...wack the starter with a hammer
Ha! Confirmation from someone that knows something. I knew I wasn't just doing this as a result of some drug-induced hallucination. Seems like lack of use would make this type of therapy more necessary.
Old 10-18-2002, 12:23 PM
marcesq's Avatar
Nostatic:
You are too kind, but what you don't know is that I fix everything that doesn't work right with a hammer.
Old 10-18-2002, 12:31 PM
nostatic's Avatar
hammer...vice grips...plastic explosives. It's all good.
Old 10-18-2002, 12:36 PM
Bob,
If the battery does have a full charge and your grounds are fine, try "bumping" the starter. I have a "dead" spot on my starter where the starter will not engage. If I put the car in 3rd gear and rock the car back and forth a couple of times, I can get the car to start. Apparently the motion moves the starter brushes away from the dead spot.
It's worked for me, give it a try. Good luck.
Neil
'73 911S targa
Old 10-18-2002, 12:54 PM
