-   -   Need input - BBS motorsport wheel refinishing (http://forums.pelicanparts.com/porsche-911-technical-forum/846805-need-input-bbs-motorsport-wheel-refinishing.html)
Sicklyscott 04-12-2015 04:46 PM
they look awesome!
NeedSpace 04-12-2015 07:43 PM
I cannot believe how nice and "modern" the bbs wheels look. Used to only seeing it in the familiar gold, the gray makes them look quite nice.
paul.911 04-13-2015 05:55 AM
Wow those look amazing. What are your offsets in the rear?
skinnerd 04-13-2015 09:31 AM
The rear wheels use a 5" outer halve along with a 6" inner halve.
The backspacing is about 5-9/16" (tad over 5.5").
paul.911 04-16-2015 09:31 AM
Came back just to see these wheels, they look too good.
I need to learn how to build wheels, brand new 3 piece wheels are outrageously priced nowadays.
skinnerd 04-16-2015 10:43 AM
Relatively simple to do....regardless what a wheel manufacturer may tell you.
Always use new O-rings between the wheel halves.
Make sure everything is clean.
Bolt them up, and torque to ~13 ft-lbs.
I then run a bead of silicon sealant around the entire perimeter where the O-ring
is as a backup against air leaks.
Sometimes good 2nd hand wheel halves are available.
If not, new ones are not inexpensive.
I spent $150-200 per halve.
paul.911 04-16-2015 04:07 PM
Nice I appreciate that, I'll do some hunting around and hopefully you see me posting about it soon!
Grand-sapin 05-08-2015 08:59 AM
What size are your barrels? inner and outer? thanks!
Fast Mike 05-08-2015 01:14 PM
Excellent!
Geneman 10-20-2018 12:48 PM
who do you guys recommend to polish the chrome 3 pc rims from E50 bbs wheels? does all reed do the rims only? i will reassemble myself.
thanks .
frank
