911 carrera 3.2 (1985)
kees's Avatar
Porsche Crest Conical screw head shift rod
I'm trying to remove the conical screw from the left side of the head shift rod. There isn't much space and I don't want to ruin the screw. The allen key seems too long/wide to get the screw off. What is the best way to do it?
Kees.
Old 02-08-2015, 08:45 AM
slice off about half the length of that allen wrench. on the short end of course. probably need to slip a short length of metal tube or something over the wrench for some leverage to crack the screw loose.
206 637 4071
Old 02-08-2015, 08:50 AM
Tom '74 911's Avatar
You could also loosen the other end of the shift rod @ the coupler (mark it's position first w/a sharpie so you can easily reset) so you can rotate the shift rod 90 degrees for easier access to the allen screw @ the front...
'74 911 Red Sunroof Coupe, 3.6L, etc...
'76 912 Yellow SPEC 911/911CUP
Old 02-08-2015, 08:57 AM
Yep. Cutting down an allen wrench will work to.
Good luck,
Dave
Dave McKenzie
1984 Carrera 3.2
1984 928S Automatic
2001 996TT
Old 02-08-2015, 09:22 AM
kees's Avatar
Porsche Crest
Thank you all.
Cutting down the allen wrench worked perfectly.
Old 02-08-2015, 10:11 AM
