Spiderman
Jesse16's Avatar
Tow Hooks for Impact Bumper Cars ?
I did some thread searching but pickings look slim. Anything cool that can be added/fabbed that doesn't look junky when not at the track for a rubber chin spoilered 87 with stock bumpers and impact tubes ? Also the rear ?
I'm pretty sure the bumpers and shocks are robust enough to pull the car from all but the worst situations. I'm leaving the stock aluminum bumpers there for street use.
Midnight Blue 08 Cayman S, Fun/Track
Black 12 VW-GTI, work
Mexico Blue 87 Carrera, sold, sad, not enough garage space.
Old 01-20-2015, 12:51 PM
Cory M's Avatar
not cheap, but Rennline makes a hidden tow hook system for front and rear stock bumpers:
Rennline Screw in Tow Hook System for 911 - Porsche-Rennline, Inc.
Old 01-20-2015, 01:17 PM
slimlynn1's Avatar
+1 nice product, looks classy and easy to install.
Old 01-20-2015, 01:48 PM
Spiderman
Jesse16's Avatar
Don't you lose the "impact" function when you remove the stock unit for the rennline one , or is there just no other way. Definitely easy now with everything apart.
Old 01-20-2015, 02:06 PM
Forum member "Low Miles" makes a nice set of hiddden hooks - send him a PM
Old 01-20-2015, 03:03 PM
Spiderman
Jesse16's Avatar
Worth a shot, done. Thanks
Old 01-20-2015, 04:09 PM
Recently Disbanded
juanbenae's Avatar
nylon strap works nice. they tuck away when not in use, strong & cheap. i had one sewn up at a shoe repair place, attached it to 2 of the 3 front a-arm mounts with the stock fasteners. you should be able to slip it thru the slight gap between the stock valence bottom of the bumper.. old out of date harnesses, old tie down straps, or buy a nylon strap at harbor freight and cut the loops off each end so you got a front & rear.
Old 01-20-2015, 05:36 PM
Banned but not out, yet..
RSBob's Avatar
Curious of how you attached the straps to the A arm mounts. Did you attach a large grommet to the straps which you then put one of the A arm bolts through?
Old 01-20-2015, 06:48 PM
Spiderman
Jesse16's Avatar
The strap is an interesting idea, thanks.
Old 01-21-2015, 06:09 AM
