What happened to my clutch today?
Coming back from Cambria today during a routine upshift I heard and felt something "pop" when I pushed in the clutch to move from 2nd to 3rd.
My passenger said it sounded like a pop. Driver of the car behind me said he saw something metallic fly out from under the car. Drove back couldn't find anything. Immediately the clutch travel was less and felt harder than normal. But I could shift gears. Later on the clutch returned to normal feeling with full range of travel, then it went heavy again. Anyone know what might have happened? I was going to take it in for some other work this week and will have them fix this, just wondering (hoping) this is something minor. Thanks. Pete 86Carrera |
Senior Member
Seem to remember that some cars have a "helper spring" on the clutch arm and could this have possibly popped off?
Look here: http://www.pelicanparts.com/techarticles/911_clutch_cable/911_clutch_cable.htm JA
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB Last edited by Joeaksa; 10-20-2002 at 09:06 PM.. |
Senior Member
I think the G50s didn't start until 1987 model year, so you'd have a 915 tranny like mine. Your helper spring probably broke. It is shaped like a horseshoe. You'll see what's left of it if you look under there. Right under where the tranny and the engine connect. it's a horsshoe-shaped leaf spring, about 3 or 4 inches in diameter.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
I'd take a close look at the horseshoe spring. It should consist of 3 strips of bent metal. I bet 1 of the inner two bands broke.
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
Senior Member
Sure sounds like the horseshoe spring to me. Now is the time to replace the cable, spring, and rebuild your pedal rack. I say this all the time, but the difference is amazing!
John
'78 Targa in Minerva Blue |
