Dan Morton's Avatar
oil tank breather hose to rain shields
I'm looking to route the oil tank breather hose to my PMO style rain shields on my carbs. Car is a 1968 911 with Webers and the stock oil tank. The current setup uses the k&n filter. The hose is completely saturated in oil and needs to be replaced, I would assume I can clean the filter but I'm curious as to what type of setup would be required to eliminate the filter and go to the rain shields.
Thanks,
Dan
--Dan
1968 911 Coupe
1970 911T Targa
1995 993 Coupe
1997 993 Targa (sold)
Old 01-16-2011, 07:56 PM
brads911sc's Avatar
I use a catch can... My PMO ITB Project Page 7 Has my catch can pics...
Many other examples out there...
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling.
Old 01-16-2011, 08:02 PM
Plumbed mine out the front of the tin, over the trans and down to the ground. Dont need oil in the carbs or fumes in the car.
Old 01-16-2011, 08:43 PM
Dan Morton's Avatar
Thanks. I didn't even think about just venting out to the ground.
-Dan
--Dan
1968 911 Coupe
1970 911T Targa
1995 993 Coupe
Old 01-17-2011, 05:33 PM
-Dan
Under certain conditions, crankcase pressure and/or g-forces can force oil out of the vent tube. That's why the suggestion to interpose a vent tank between the oil tank and the ground or intake tract (also suggested). You want to avoid venting liquid oil onto the ground where it might interfere with rear traction.
BTW, most track regs. require a puke tank for just that possibility.
Sherwood
Old 01-17-2011, 09:59 PM
More to the point, the center placed, post axle, vent drain hose plumbing works well. Also, you must run a proper air filter, of whatever sort. Rain guards are cute, but the stock air distributor is the solution.
Old 01-17-2011, 11:57 PM
brads911sc's Avatar
Rain guards go over the air filter if he is running Webers or PMO's. There really is no other option. Not about being "cute".. Its all there is. All he needs is a catch can. Easy to install. Properly vented. Less than $100.
Old 01-18-2011, 06:31 AM
Home of the Whopper
Thanks Brad. I just ordered a catch can. Sweet looking car BTW.
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller
Old 01-18-2011, 09:09 AM
RETIRED
Joe Bob's Avatar
-Dan
Not the most PC solution.
Old 01-18-2011, 10:19 AM
Beyond politically correct. Don't we have enough crap in the air and ground already ..... from my leaking engine? Besides, oil will cling to the undersides of your car. Good enough reason?
Sherwood
Old 01-18-2011, 10:39 AM
On my 83 911 The oil tank itself was used as a catch can.
I just used that and then routed the vent from there to the air cleaner.
Old 01-25-2015, 04:40 AM
