So the battery drain was the windows always being powered and the FP issue was simply something dumb done by a PO.
As for a bad FP relay, if you have a bad one you can easily create a super heavy duty one by gutting it then soldering up harnesses to 2 40AMP standard square relays. I have my relay done this way and it never heats up and most likely will last forever. And if it goes bad it's easy simple replacement with a standard 40Amp relay. If you want details let me know. |
Thanks Sal, GK |
http://forums.pelicanparts.com/porsche-911-technical-forum/364450-wide-band-o2-data-logger-84-89-carrera.html |
Hello all,
I'm having the same problem with my 88 coupe. With relays removed, windows and sunroof stay energized. With the #1 fuse removed, windows stay energized. With #2 fuse removed, windows stop working. Smoove1010, I was wondering what the location of the odd connector that tied all the wires together was and if that may be a way to solve my issue as well? In your pictures it appears to be close to the brake booster mount, but I see no such connector on my car. Thanks for any help with this odd problem I have spent years living with!! |
westcoast911 -
Take a look at this pic from early in the thread: http://forums.pelicanparts.com/uploa...1422228806.jpg The J-Connector, which in my car's case was apparently incorrectly applied, was under the part of the wiring harness that's obscured by the fuel filler neck. It's at the 6 o'clock position in this picture just left of that blue crimp connector. You might need to dig a little to get to it IF that's your culprit. My advice - do the most basic thing first - make sure your interior light plunger switches are operating correctly. This seems to solve most problems of this type. They didn't in my case because somebody molested the wiring in my car. Bless those PO's and their wrenches... GK |
| All times are GMT -8. The time now is 01:05 AM. |
