Tank is leaking from the drain plug in middle of tank underneath as well as from fuel pump area. I removed the plug, sanded surface clean and replaced the o-ring, and it does not seep anymore, also replaced rubber fuel line from pump. drove around and all was well until i let the car sit for a few hours. Now it is leaking... vapor expanding in tank perhaps creating internal pressure ? could my charcoal canister be to blame for this ? is this a common place for a leak ? I need some ideas/suggestions... original pinhole leak has been braised shut and now this... I will re-torque everything i suppose... gas fumes are driving me nuts!
85 carrera 3.2 Last edited by aleminx; 01-27-2015 at 12:06 PM.. |
Fleabit peanut monkey
You clearly did some good with your repairs but the gas cap is pretty notorious for stinking things up. For $10 it's worth it to replace unless you have seen actual leaking. Your charcoal canister is in the right side rear fender. It does not hold any pressure. It's a pass through for the vapors. Doubt that is your problem.
1981 911SC Targa |
leak appears to be even worse than last night... fuel is dripping from the front passenger side of the tank below the lip.... will have to get in deeper . guess the tank comes out for the fifth time! updates to follow shortly. what a pain!
85 carrera 3.2 |
Ugh. Is there anything even over there for the tank to leak save a hole?
1981 911SC Targa |
Just discovered Another tiny rust hole/crack in the seam weld. Hopefully this is the last one.
85 carrera 3.2 |
Replace the tank don't repair it.
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera |
| Tags |
| fuel , gas , leak , tank |
