web geek
emptyo's Avatar
Send a message via AIM to emptyo Send a message via Yahoo to emptyo
Here you go!
Michael O'Neal -
69 RSR Clone(ish) - Read about the build: http://bit.ly/69porschersr
Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/
Old 01-28-2015, 04:28 PM
83 911 Production Cab #10
JJ 911SC's Avatar
Originally Posted by hdrockerroller View Post
Excellent picture, exactly what I was looking for.
So the PMOs connect directly to the linkage rod that comes through the tin.
Oui... There is 2 pivot point on the triangle for either tall or short manifold adapter. The instruction are pretty strait forward but you would notice right away if you pick the wrong hole.
Hard to see on the picture but I got short adapter so the horizontal line going forward is hook through the top hole (shown). If I had the tall one I would use the button hole (not shown) so that the rod going forward would still be in the horizontal plane.
Who Will Live... Will See
Old 01-28-2015, 04:40 PM
JJ 911SC's Avatar
OK, last trip to the garage for tonight...
Now you can see the other hole. So if I had the taller adapter, I would use the empty hole in order to keep the rod (that goes forward) horizontal.
Old 01-28-2015, 04:54 PM
Gordo2's Avatar
Take a Breater
Recommendation: Take a moment to look at the links that have been posted in this thread - fairly certain they will answer most of your questions.
Good questions and responses, but at some point it's going to take a little studying.
Gordo
Don Gordon "Gordo"
'83 911SC Targa
'87 FJ-60 TLC
Old 01-28-2015, 06:06 PM
A source for K-nuts
Several people have recommended replacing the 13mm head M8 intake manifold nuts with 10mm head M8 k-nuts for better clearance of the PMO manifolds.
This place will sell them to you, I just ordered a set.
Coast fabrication
714-842-2603
Old 01-30-2015, 10:43 AM
Straight shooter
Lapkritis's Avatar
I need a set of those... I'm on with 13mm but it wasn't fun.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 01-30-2015, 11:20 AM
Breather connections
Anyone have pictures of the breather connections?
Do they go to the watershields on both carbs?
Old 01-30-2015, 04:01 PM
...most leave the breather connections out and vent to a catch can. I don't think there is an advantage either way, but the catch can provides a cleaner installation.
Old 01-30-2015, 07:26 PM
JJ 911SC's Avatar
That is what it look like. I ran with it for a year before going the Catch Can way.
Old 01-31-2015, 01:09 PM
Great pic and super clean install of the PMO oil catch set up!
1982 911 Targa, 3.0L ROW with Webers
Old 01-31-2015, 01:43 PM
Bird911's Avatar
Very nice engine JJ. Pictures like these are just pushing me more to the PMO way !
Hugo
Old 01-31-2015, 03:04 PM
Did you have issues with Oil in the carburetors when you had the breathers attached there? I've heard other people com;ain of the oil smell when they vented directly into the engine compartment.
Old 01-31-2015, 03:44 PM
JJ 911SC's Avatar
Did you have issues with Oil in the carburetors when you had the breathers attached there? ...
No and for the smell since I drive with the top down all the time nothing come back in the cabin.
Old 01-31-2015, 05:09 PM
Left PMO manifold with studs installed and linkage plate
Here's the left manifold with the studs now installed and the linkage plate installed.
Old 01-31-2015, 07:48 PM
Air cleaner plate and stud
Here's the air cleaner plate and studs installed on one of the carbs.
Old 01-31-2015, 07:57 PM
Bench setup
Carbs sitting on manifolds.
Old 01-31-2015, 08:01 PM
Ok, more pondering about an oil catch can, several people are using that, but isn't that the whole point of the breather being routed into the oil tank then coming out of there. Isn't it really using the oil tank as a catch can. I'm not really seeing why another catch can would be needed. Any thoughts on this?
Old 01-31-2015, 08:58 PM
Straight shooter
Lapkritis's Avatar
That's how mine is. Just a breather filter on top of the stock oil tank.
Old 02-01-2015, 07:43 AM
Manifolds
Here are both manifolds with studs installed, linkage plates and the linkage installed on the front shaft.
Old 02-01-2015, 08:34 AM
adjustment
On the left manifold the linkage connection plate has a small amount of adjustment for the length. This is where the shaft that runs between the two carburetors will attach. Don't crank this fitting down until its been adjusted when installed on the car.
NOTE: both of these fittings on the left and right manifold were un-tightened when I received my PMOs, be sure they are tightened down when you install.
Old 02-01-2015, 08:44 AM
