Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 911 Technical Forum
$ Short's Avatar
Spam reported
Kurt
1988 Carrera
Granite Green
Old 02-10-2015, 04:28 AM
  Pelican Parts Technical Article Directory    Reply With Quote #61 (permalink)
Originally Posted by $ Short View Post
Spam reported
My post is spam?
Old 02-10-2015, 09:46 PM
  Pelican Parts Technical Article Directory    Reply With Quote #62 (permalink)
83 911 Production Cab #10
JJ 911SC's Avatar
Originally Posted by snbush67 View Post
My post is spam?
No but there was a spam posting between you and $ Short which was removed.
Who Will Live... Will See
83 911 Production Cab #10, Slightly Modified: Slanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger
Old 02-11-2015, 02:05 AM
  Pelican Parts Technical Article Directory    Reply With Quote #63 (permalink)
more pics coming
I will be adding more pictures soon (eventually)
Right now I'm waiting for my distributor to come back from getting rebuilt and recurved by Barry Hershon at IAE. As soon as that's back and the car is running again, the next available weekend I'll put the carbs in and photograph everything. Meanwhile, thread is open for anyone to post more PMO install pictures, or your experience balancing them, or details about getting the jets right, etc.
Old 02-11-2015, 05:36 AM
  Pelican Parts Technical Article Directory    Reply With Quote #64 (permalink)
Oh, thanks. I must have missed it, I wasn't denying that my post was spam though.
Old 02-11-2015, 06:08 PM
  Pelican Parts Technical Article Directory    Reply With Quote #65 (permalink)
injection system removed
Here's a shot of the engine with the injection system removed.
The intake runner nuts were a battle, but I used a swivel socket and a magnet to pickup the nuts and washers.
Old 02-20-2015, 04:52 PM
  Pelican Parts Technical Article Directory    Reply With Quote #66 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
old intake studs
Here's a picture of the original intake studs.
These need to be replaced by slightly longer studs that come with the PMO complete kit.
Old 02-20-2015, 04:57 PM
  Pelican Parts Technical Article Directory    Reply With Quote #67 (permalink)
intake studs removed
Here's a shot of the intake studs removed.
I let these soak for a bit in liquid wrench penetrating oid, then used the double nut method to remove them. All in all they came out pretty easy.
Old 02-20-2015, 05:01 PM
  Pelican Parts Technical Article Directory    Reply With Quote #68 (permalink)
Old and new stud
Here's a pic of the old and new stud.
The new ones are only a little longer to account for the heat shields that go between the head and the PMO intake manifolds.
Old 02-20-2015, 05:03 PM
  Pelican Parts Technical Article Directory    Reply With Quote #69 (permalink)
new studs installed.
Here's a shot of the new studs installed.
Old 02-20-2015, 05:05 PM
  Pelican Parts Technical Article Directory    Reply With Quote #70 (permalink)
PMO regulator
Here's a shot of the PMO regulator installed and connected to the inlet and return lines.
The bottom connection is the inlet and the top connection is the return line.
This is not marked on the regulator, but PMO documentation has a diagram that shows which way to hook it up.
Old 02-20-2015, 05:09 PM
  Pelican Parts Technical Article Directory    Reply With Quote #71 (permalink)
More PMO install pics
More PMO install pics.
Old 02-22-2015, 09:28 AM
  Pelican Parts Technical Article Directory    Reply With Quote #72 (permalink)
PMO installation
Final shots of PMO installation.
Old 02-22-2015, 09:36 AM
  Pelican Parts Technical Article Directory    Reply With Quote #73 (permalink)
The only issue I ran into at all during installation was that the PMO intake manifold gaskets were slightly too large to fit through the fan shroud cover onto the heads. The thermal insulators were perfectly sized however so I used them as a template to trim the gaskets down so they would fit. Actually used a bench grinder to shave gaskets down evenly and it worked great, could trim more than 1 at a time.
Old 02-22-2015, 09:39 AM
  Pelican Parts Technical Article Directory    Reply With Quote #74 (permalink)
Oh yea, I did run into one more problem but it was pretty easily solvable. When I first hooked up all the linkages I could not get wide open throttle, the linkages from the bellcrank at the transmission seemed too long. After taking up all the slack in the adjusters at both the linkages coming to and leaving the bellcrank at the transmission I had enough movement to obtain WOT.
Old 02-22-2015, 09:42 AM
  Pelican Parts Technical Article Directory    Reply With Quote #75 (permalink)
Nicely done, now comes the fun part.
Old 02-22-2015, 11:39 AM
  Pelican Parts Technical Article Directory    Reply With Quote #76 (permalink)
JJ 911SC's Avatar
+1... Next pic sow show the fan spinning
Old 02-22-2015, 11:59 AM
  Pelican Parts Technical Article Directory    Reply With Quote #77 (permalink)
oh btw, it fired right up.
I'm taking it to jones autowerks in san antonio for setup and balancing.
They've been setting up 911 carbs for over 40 years.
Old 02-22-2015, 12:23 PM
  Pelican Parts Technical Article Directory    Reply With Quote #78 (permalink)
Any feedback? Did you get it all sorted?
Old 09-30-2015, 12:04 AM
  Pelican Parts Technical Article Directory    Reply With Quote #79 (permalink)
Great pics and good info. Question: When installing the manifolds is the order from the engine up - gasket, thermal insulator, gasket, manifold?
1971 Light Ivory 911T - Gretchen - sold
Looking for Engine # 6114097
2010 Cayman
Old 12-31-2016, 04:05 PM
  Pelican Parts Technical Article Directory    Reply With Quote #80 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
