non-whiner
mreid's Avatar
Yes, that is the order.
"Too much is just enough."
Old 01-01-2017, 08:49 AM
hd fantastic thread ... i am installing 50mm this weekend in my RSR which was burned out.... yuk
impt... when mounting the manifold to the block. do you use 2 gaskets and 1 black insulator for each cylinder? meaniing, is the sequence: block-gasket-black thing-gasket-manifold?
also i assume there is a gasket between manifold and the actual carb.
thanks very much.. email me if you can frank
rauscher@wistar.org
Old 11-10-2017, 01:47 PM
mreid did you just answer this ??? incredibly fast are you the moderator?
Old 11-10-2017, 01:48 PM
83 911 Production Cab #10
JJ 911SC's Avatar
Originally Posted by JJ 911SC View Post
+1... Next pic sow show the fan spinning
Still waiting...
Who Will Live... Will See
Old 11-10-2017, 02:30 PM
