Cylinder/piston is this correct?
Is this the correct orientation, for a 1982 cylinder and piston install. Long fins down in cylinder and large cut up on piston? They are JE 9.5 cr Pistons.
Please excuse brevity and spelling errors. Sent using iPhone
Old 01-29-2015, 08:17 AM
yup.
206 637 4071
Old 01-29-2015, 09:47 AM
Looks fine.
I hope you are not using that Autozone SN-rated motor oil in this engine as thats a big heap of trouble.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 01-29-2015, 11:25 AM
Straight shooter
Lapkritis's Avatar
Easiest way to remember is your intake valve is always larger than the exhaust valve... the intake is on top of the engine and exhaust is on the bottom.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 01-29-2015, 11:51 AM
Ok thanks guys. Just using the autozone oil to whipe on parts to get things to slide together. Will use castrol gtx when I fill it up. Thanks again
Old 01-29-2015, 02:48 PM
Don't use GTX,..........use Brad-Penn as its FAR FAR better in every way.
Its a long story and goes back 25+ years,.....
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 01-29-2015, 03:11 PM
