Diss Member
Find a slave cylinder that will fit...
Someone posted up a link to a European site that is selling a larger diameter slave cylinder to reduce the pedal effort on the 3.2 Carreras: MPL-Tuningparts (Productdescription Porsche)
It is a nice looking product and obviously all custom but I just can't choke down $200 for a slave cylinder. Tore down a slave cylinder to get the dimensions of what we would need. Stock is a 24mm bore with a 60mm spacing on the vertically aligned mounting studs. What we need is a 28mm or 1.125" bore with the 60 mm or 2-3/8" stud spacing. Anybody have access to an interchange with dimensions or a serious junk pile to go through? ---------- We could come up with a smaller bore master cylinder but I'm not tearing that apart to get dimensions and it would be a harder swap.
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
