Plus, that worked to prove my '78's CDI was going TU... TU was the direct result of intermittent alternator/VR over-voltages. CDI has NO protection against excessive, >15V, supply voltage. SmileWavy |
Afternoon all,
Having the same problem as the OP, can the CD box be a problem, yet sound normal (whining?) Also the white wire from the CD box to the coil, what voltage should I see on that wire and should it be steady or pulsing? TIA Glen 78SC with Bitz EFI |
