beamonk's Avatar
Send a message via AIM to beamonk
half-shaft questions
Hello all, today I had all of the bolts back out on one of my axles. My fault as I forgot to go retorque them. I was going slow so no damage and only one of the allen heads broke. Question is, what type of washers do these things use, I have half spring washers and half lock washers. Are these stretch bolts that need to be replaced ?
Thanks as always
John Brasfield
91 C2
78 SC For sale
76 3.6
68 Datsun 2000 Mr. Magoo, 02 330ci
Old 02-13-2003, 06:41 PM
Year and model? The half-shaft CV joints which use lock washers utilize the Schnoor type which is a "toothed Belleville" (dished shape) lock washer. The lock washers should be replaced everytime the screws are loosened or removed. The screws may be reused; they are not "stretch" bolts. Do not lubricate the screw threads. Do you know the proper torque for your CV joint screws? Are there four or six screws per CV joint? Cheers, Jim
Old 02-13-2003, 07:22 PM
beamonk's Avatar
it is a six bolt off of a 76. I am aware of the schor washers, I guess mine all got lost. I will try to track some down somewhere. My buddy said it is a good idea to clean all threads with berrymans carb cleaner including the axle shaft threads. Dry them off good and use blue locktite if you wish.
John Brasfield
91 C2
78 SC For sale
76 3.6
Old 02-13-2003, 07:49 PM
Then you have 8mm screws; 36 ft-lbs. Jim
Old 02-13-2003, 07:57 PM
beamonk's Avatar
Thanks Jim
John Brasfield
91 C2
78 SC For sale
76 3.6
Old 02-13-2003, 08:12 PM
Actually I'm pretty sure some year(s) had stretch bolts?!? Not sure which though.
Old 02-13-2003, 10:33 PM
In 1984 and later the CV joint screws ( the screw part no. changed) no longer came with locking washers. This may mean they are stretch bolts but I suspect instead it means they came with a some type of prevailing torque locking feature such a distorted thread profile. But 1983 and earlier the CV joint screws can be reused if in good condition. Cheers, Jim
Old 02-14-2003, 05:58 AM
carnut169's Avatar
FWIW I also had the half shaft come loose from the trans on my 87... on the highway! I was lucky as there was no damage, but when I put the new half shaft in I used new bolts with the schnoor washers. Can't be too careful!
Sean O.
Atlanta, Ga.
96 Van Diemen Formula Continental
01 2500HD
Old 02-14-2003, 07:43 AM
Senior Member
Did my 30k inspection several years ago with a ex-Porsche mechanic. We did the half shafts and re-assembled them using the old bolts and not a problem after 25k of driving. Either the 85 model bolts are not the "use once" type of bolt or I am very lucky!
Joe
Old 02-14-2003, 07:48 AM
gblumenstock's Avatar
Where did you get the washers? I tried to get lock washers from PP and received the split type.
GB
Old 02-14-2003, 11:26 AM
cary's Avatar
Search : Schnoor with Early S Man and you'll find it.
Good Luck
Cary
77 Carrera RS w/3.2 #59
73 914S 2.0 AG
73 914 1.7 Driver ( daily driver, under complete rustoration )
74 914 2.0, 71 914 Tub, 74 914 2.0 Tub + 73 914 donor
Old 02-14-2003, 07:19 PM
